Overfender flare creation - Page 7 - LotusTalk - The Lotus Cars Community
 6Likes
post #121 of 157 (permalink) Old 01-14-2016, 05:01 AM Thread Starter
glagola1's Avatar
Here's a recent action shot that tells the story pretty well. They turned out incredibly buff so nailing cones with them is really not an issue at all.
glagola1 is offline
post #122 of 157 (permalink) Old 01-14-2016, 07:45 AM
I'm in the process of putting together a fresh K24 with a snail so I need all the contact patch I can get... I know you can relate. I prefer your setup to any of the other offerings out there. In the past you had mentioned redoing the fronts. Does that mean that you would be planning on using your current setup on the rear going forward? If I can assist in anyway let me know! PM if that's easier
lordofmpower is offline
post #123 of 157 (permalink) Old 01-14-2016, 07:55 AM Thread Starter
glagola1's Avatar
If I had a donor car over the winter I could totally do it starting in about 2 weeks. I'd redo the rears as well to match the style of the fronts... if they turned out ok.
Hmmmmm, I wonder if I could find a donor.
or maybe I could hang on to my front clam while the turbo gets installed.
glagola1 is offline
post #124 of 157 (permalink) Old 01-14-2016, 08:08 AM
not sure whereabouts you are located but if you find yourself in Sacramento California you can use mine lol
wangan is offline
post #125 of 157 (permalink) Old 01-14-2016, 08:11 AM
Giantmcm's Avatar
ha ha, thanks lordofmpower. I was going to make another set (different style) this winter but then I decided I needed to add a turbo. I will certainly, eventually, be making more and when I do, I'll make them using molds so that I can make more.
Hey Glagola, which turbo are you going for...and why the change to a turbo?
Maverick ML8 - Other daily
Giantmcm is offline
post #126 of 157 (permalink) Old 01-14-2016, 08:52 AM Thread Starter
glagola1's Avatar
I'm in Atlanta.
I'm not switching to a turbo.
glagola1 is offline
post #127 of 157 (permalink) Old 01-14-2016, 09:08 AM
Giantmcm's Avatar
I'm in Atlanta.
AHHHHH!!!
Giantmcm is offline
post #128 of 157 (permalink) Old 01-14-2016, 09:38 AM
fsparv's Avatar
Hmm, it does seem there are several levels of ambiguity in your previous statement about "needing a turbo"... perhaps it's for your lawn mower? Just what are you doing with that turbo anyway
2005 Lotus Elise, Starlight Black # 111 SSM NER SCCA Solo - 1835lbs up to 1.65 Lat [email protected]~55mph (asphalt) 193whp 142wtq Normally Aspirated.
fsparv is offline
post #129 of 157 (permalink) Old 01-14-2016, 09:42 AM
My rear clam is in my sunroof much to the dismay of my wife, haha not sure that gets you close enough though since half of the rear is on the skirt. I'm in Northern Virginia, it's at least the right coast.
post #130 of 157 (permalink) Old 01-14-2016, 09:54 AM
What might he mean if he says he's adding a turbo, but not switching to a turbo...
David de Regt - Bellevue, WA
codingparadox is offline
post #131 of 157 (permalink) Old 01-14-2016, 10:25 AM
Conechaser's Avatar
Fender Flares
My attempt at covering Hoosier A7's in 295's and 275's in the rear and front.
Conechaser is offline
post #132 of 157 (permalink) Old 01-14-2016, 10:36 AM
dma550's Avatar
Sexy! I bought a 911 RSR replica once where the flares were sheet metal screwed on. Looked bad ass!
David Avery
06 Lotus Exige | 08 BMW M3 Cab
visit focusedE
post #133 of 157 (permalink) Old 01-14-2016, 10:36 AM Thread Starter
glagola1's Avatar
That looks good! Is that metal? I like it. The rears are much easier to manage. The front of the Elise is really kind of challenging to resolve.
glagola1 is offline
post #134 of 157 (permalink) Old 01-14-2016, 10:47 AM
Damn, that looks awesome!
EDIT: Are those 16s up front?
Silver_Surfer is offline
post #135 of 157 (permalink) Old 01-14-2016, 01:07 PM
Conechaser's Avatar
Wide Flares
Used the same fasteners from Lotus that the other parts are attached with like the side scoops to try to make them look more OEM. The wheels were supplied by our friendly and knowledgeable go-fast guy, Fred Zust, at BWR and are Bogarts 15x10 fronts and 17x11 rears. We can't change wheel well heights in SCCA SSP autocross so the 15's are the only ones that will fit with any real width like a 275 in a Hoosier A7. Fred was great in getting these wheels done to the specs we needed to optimize grip. HE'S THE MAN!
post #136 of 157 (permalink) Old 01-14-2016, 01:57 PM
Hmmm.... The tires in the pics you posted look like RS3s, did you fit a 225/45/15 on your 15x10s??
post #137 of 157 (permalink) Old 01-14-2016, 04:38 PM
Conechaser's Avatar
Nope, 275/15's Hoosier A7 in the front and 295/17 in the back. Also went to a wider flare in front and back then shown. Accidentally used old flare pictures. New wider flares are shown in separate new post today
post #138 of 157 (permalink) Old 01-14-2016, 04:41 PM
You should scroll up and recheck the picture you posted. Those are definitely RS3s or something very similar, not A7s.
post #139 of 157 (permalink) Old 01-14-2016, 04:42 PM
Ooooooh, ok. I wish someone would make a 100-200 tw tire bigger than 225
post #140 of 157 (permalink) Old 01-15-2016, 04:42 PM
because racecar
dallasreed's Avatar
Run 16 inch fronts
Then R888
dallasreed is offline
