what's everyone's aero pkg look like? - Page 2 - LotusTalk - The Lotus Cars Community
 3Likes
post #21 of 26 (permalink) Old 09-14-2016, 10:49 AM
glagola1's Avatar
For SSM, there is no allowance for replacing or adding a diffuser. That means you can't touch oe... not even to fill the hole.
I'm not versed on the XP rule set.
glagola1 is offline
post #22 of 26 (permalink) Old 09-14-2016, 11:16 AM
XHILR8N!'s Avatar
RideMooch likes this.
2005 Elise LRG, track prepped ,
2016 370Z Nismo
2013 Bentley Continental GT Speed 2019 Lexus LC500
XHILR8N! is offline
post #23 of 26 (permalink) Old 09-15-2016, 05:40 AM Thread Starter
user /tron
RideMooch's Avatar
Originally Posted by kfennell View Post
My reading shows a 25" diffuser with strakes a minimum of 6" apart is allowed, my diffuser meets these rules (difflow railer I think), can anyone show me I am wrong?
It does look like the GRP wing above would NOT be AX legal in any class?
Where are you getting that diffuser rule? SSM rules do not allow diffuser change from OE.
copied and pasted SM rules on aero below. If doesn't say you CAN do it, you can't.
Originally Posted by SCCA SM rules
K. Aerodynamic Aids: Wings may be added, removed, or modified. Non-OE
wings may only be attached to the rear deck/hatch area behind the center-
line of the rear axle. The total combined surface area of all wings shall not
exceed 8 sq. ft. (0.7432 m2) as calculated per the Wing Area Computation
in Section 12. The number of wing elements is limited to 2.
Wings, and any component thereof, may not extend beyond the vehicle
width, as defined by the outermost portion of the vehicle doors, less mir-
rors, door handles, rub strips, and trim. In addition, no portion of the wing
or its components may be more than 6.0 forward of the rear axle, more
than 0.0 beyond the rear most portion of the bodywork, or more than 6.0
above the roofline of the vehicle, regardless of body style. For convertibles
and roadsters, the highest portion of the windshield frame will be consid
ered the highest portion of the roof; however, a convertible or roadster uti
lizing a hardtop will use the highest portion of the hardtop as the roofline.
Reinforcements to the wing mounting area may be used, but may serve no
other purpose. Body panels to which a wing mounts must remain func
tional (e.g., trunk lids and rear hatches must open). Wing endplate surface
area is limited to 200 sq. in. (1290.3 cm2) each and limited to a maximum
of 2.
Except for standard parts, wings designed to be adjustable while the car is
in motion must be locked in a single position.
Canards are allowed and may extend a maximum of 6.0 (152.4 mm) for
ward of front bodywork as viewed from above. No portion of the canard
may extend past the widest part of the front bodywork/fascia as viewed
from above. Canard area will be measured in the same manner as wings
using Section 12. Canard area may not exceed 15% of total wing
allowance. The sum of canard area and rear wing area may not exceed the total
wing allowance.
L. Front splitters are allowed and shall be installed parallel to the ground
(within 3 fore to aft) and may extend a maximum of 6.0 (152.4 mm)
from the front bodywork as viewed from above. Splitters may not extend
rearward past the centerline of the front wheels. No portion of the splitter
may extend beyond the widest part of the front
Aerodynamically functional vertical members, such as splitter fences
or endplates, are not allowed.
~Matt
'06 CO Elise
'17 Toyota 4Runner TRD Pro, cement grey
'16 VW GTI, Wifey's ride
Past toys: '02 WRX | '06 STI | '14 Subaru BRZ
RideMooch is offline
post #24 of 26 (permalink) Old 09-15-2016, 06:53 AM
kfennell's Avatar
What class can I run in with a diffuser? It looks like it is even banned in XP? Sorry I just searched for diffuser and thought I was in a different section then I was.
kfennell is online now
post #25 of 26 (permalink) Old 09-15-2016, 07:00 AM Thread Starter
user /tron
RideMooch's Avatar
You can run one in Modified (DM or EM)... Don't know about XP, but I dont see any allowance in the Prepared rules. XP is weird though. Find a rear photo of the BWR XP car.
~Matt
'06 CO Elise
post #26 of 26 (permalink) Old 09-15-2016, 07:27 AM
kfennell's Avatar
I did, that was my research into XP Easier then reading the rule book. Now back to the book to figure which of those is appropriate...
