1 - 13 of 13 Posts
'07 Exige S
Hi guys, I posted last fall that I bought an ‘07 Exige but the heat does not work. It appears that the controls work fine, the thermostat is functioning with proper temp readout.
The suggestion was the flapper May be stuck in the AC position. So yesterday I finally pulled the front clam. Here is a photo from the front of the car looking inside the heater/AC unit. The flapper is on the left. Is that for AC or heat? My temp control knob is turned towards heat. If it is stuck what’s the best way to nudge it over?
Thanks
Henry
blender actuator has gone out if it's like my '06 - but without taking out the heater box, it seemed impossible to get to the screws and replace it - so I'm waiting until the end of the summer before I crack open my AC lines and have to recharge the system afterwards
Lotus Part #: A117M6052S or Bergstrom Part #: 2199069 - I was able to get one for around $20
There are three wires on the harness ground 12 volts and the output of the heat knob
It is worth checking to make sure you have the correct voltage at the harness
If you are taking it out do your fan resistors and any ac mods
'07 Exige S
I am a good shade tree mechanic, but electrical stuff just baffles me.
Here are a few questions that I need help with.
Since the radiator is out of the car I cannot start it.
I bought the car last October (only has 7000 miles) and did not test the functioning of the heat or AC (duh)
The fan works on all three speeds. The blue AC light illuminates
1. If you power on the ignition all the way and turn the heat/AC knob should the flapper move? If yes, what are the chances the knob control is cooked vs. something internal in the heater box?
2. Or will it not move unless there is a certain ambient internal temperature.
3. It was suggested to "test" the power to the flapper. Is that done up at the control knob or down on the heater box?
4. Isn't there either a fuse or relay for the flapper or entire heater box assembly?
Thanks guys.
Henry
'07 Exige S
test it down close to the flapper. There is a white connector with 3 wires black, green something, yellow something....look in the shop manual
even thought the fan works today, if the resistors have not been done, it will fail eventually
If the ignition is on the flap should move with the heater control knob. ie it should move to the heater side when the heater control is turned to cold and move to the AC evaporator when the knob is turned to hot. The ambient temperature has no effect and the engine does not need to be running for the flap to move.
'07 Exige S
If the heater/AC knob is defective has anyone come up with a non-Lotus OEM replacement?
If so can you share a part # ?
Thanks,
Henry
if you can pull the connector to the flapper servo you can (have them) measured up, one lead should be full 12V, one equals ground and one equals 0 - 5 volts (0V = closed / 5V= open flapper)
'07 Exige S
Discussion Starter #12
Well gents the "No heat" problem has been identified and fixed.
I finally got around to moving the fuse panel and all things below it to
get a better look at the connections and to test for 12v and 5v.
Turns out the green wire (right next to the red wire in the photo) was severed
from the connector. Quite thin wire. I really don't understand what prior owners do to their cars
and how these things happen.
Anyway, I touched the wire to the small part still attached to the connector and the flapper
immediately moved (yes!!!), so I set out last night to solder in new slightly longer wires (all three),
shrink wrapped and wire tied nice and out of the way. Also cleaned up the other wires that appear to come from the
actuator area.
One very vexing problem solved. As always thanks to the community for all of the suggestions and steering me in
different directions to diagnose.
Time for summer, but come November I will have heat!!
Henry
'07 Exige S
1 - 13 of 13 Posts
