1 - 20 of 37 Posts
Lotus Driving Academy
Good morning,
A few days ago, I was driving my 2005 Lotus Elise pretty hard down the interstate. My access cover in front of the diffuser (the one you remove to drain oil) came loose a little on the front part and while driving it started flapping and scraping the ground and making a terrible noise from underneath the car. It had aftermarket quarter turn fasteners that I guess didn't work to well.
I immediately pulled over on the off ramp which conveniently was right there and I turned the car off and stepped outside to see what had happened. I noticed the panel was hanging down some and a little bent up but I didn't see any loose wire connections or anything, so I was just going to drive slow home being so close to my house, and try to fix it.
I got back in the car and turned the key on and immediately noticed a check engine light, oil light, and battery light, and my shift light is blinking constantly.
I pushed in the clutch, and hit the start button (with car in neutral) and the car does not make a single sound. Nothing at all is coming on. It does 0 anything.
I tested the battery with a V meter my friend had given me earlier in the day and I had 12.0V exactly, not over (so I don't know if it has to be a minimum of like 12.5? but I wouldn't think so?)
Some friends came out and we tried rolling and popping clutch, but it just sounded like it was out of gas, and might not even be getting spark.
After a while the police showed up to make a scene and block the road which no one was on because it was 3 am in almost the middle of nowhere and we tried several more times to pop the clutch with no success. fortunately I payed $12 for roadside assistance insurance for 6 months and I had to get my lotus towed back to my house.
I checked all the fuses in the front passenger side of the clam, and the ones underneath the passenger side inside the cabin. They were all okay. I removed battery cables and put back on. My friend said something about the immobilizer/inertia switch, and I want to say he tried to reset it but I cant remember, it was when we were still on the side of road and I was on phone with tow company. My key fob doesn't work for the car and I have never used it before, I always just lock the car from the outside with the key. I door locks aren't doing anything weird and the alarm doesn't sound, but like I said the shift light still comes on everytime I put the key in. I read a lot of stuff on other people having the immobilizer issues but I have the other dash lights on that I have never had before. I also bought a code reader but it is showing 0 codes. any ideas?
Fuel pump inertia switch???????
I don't really know but it would cause your engine not to start. Can you hear the fuel pump come on when you turn the key?
Also what does your ground wire look like going to the engine?
I don't hear anything at all come on when I turn the key, Ill have to go check the ground in a few.
Try the inertia switch, its hard to find but is under the washer fluid reservoir.
I found the inertia switch but to reset it do I just unplug it and plug it back in?
Its a button. Press to reset.
Discussion Starter #10
I pushed the button multiple times with key on and off and it didn't do anything
Check all wiring around where that panel was banging around. Remove the panel and look it over good!
would that cause the check engine light and the other lights though?
The inertia switch doesn't do any of that, but the immobilizer does. I had my battery come loose once while driving and that all happened right before it ran out of fuel (the immobilizer turns off the fuel pump). It sounds more like your fob isn't being recognized. Might be all a coincidence, but does the car acknowledge the fob at all when you hit the button?
Discussion Starter #15
I don't have a fob and I have never used one so I cant answer that. Do you know how to reset the immobilizer? I thought that the immobilizer was the same as the inertia switch, I didn't know they were two separate systems. at the moment I just jacked the car and im taking off the tray to see if there is any further damage that could be the problem
I don't have a fob
I think you can stop looking at the wiring...
Traditionally, the key fob releases the immobilizer which then allows the fuel relay to operate as well as the starter. This is located behind the driver's seat and flashes lights on the dash.
The inertial switch is purely mechanical and turns off the fuel pump when you are in an accident.
There are ways around the immobilizer, but that info is in other threads I don't have in front of me right now. Search for them and you may find your answer. Even if I used those to turn off the automatic arming of the immobilizer (as has been done with your car), I'd never go anywhere without the fob. If the system was accidentally reset and went to the default settings, you need a fob.
Discussion Starter #17
Try disconnecting the battery for 10 minutes.
I just removed the access panel and everything appears to be fine. I disconnected the battery so now im just waiting, if this doesn't work I guess the immobilizer is the answer to my problems and from what it seems that's going to be a pain in the butt.
Discussion Starter #19
So after jacking the car up and placing it on rhino ramps, I removed the access panel and found no visible damage to anything besides the panel itself.
I disconnected the battery and waited 15 minutes, re connected and still am having same issue.
I pressed the inertia/fuel cut off multiple times with key on and off.
So this is almost definitely immobilizer related?
Monaco Dreamin'
From the moment you said "my shift light is blinking" I knew it was the immobilizer. I'm very surprised your car didn't come with a key fob, and unfortunately I think you're going to have to pick one up.
There is a method of disabling the immobilizer, do some searching around on the forum. I highly doubt it could be anything else.
1 - 20 of 37 Posts
