1 - 3 of 3 Posts
I've been out of the Lotus game for a while now (owned a CO 05 and 06 Sport Elise) Currently looking at an 08 SC Elise with 7500 miles.
What things should I be looking for? Any major issues, recalls? My 05 options were touring and sport package. Same with 08? Much
thanks. B Smith
PM sent. You'll need to click your avatar icon to the right of the "New" and Forums symbols to open the "conversation", which is the equivalent of a PM.
San
Note: I posted a video of what to look for when buying one of these; no idea of where. Golden Gate Lotus Clubs may have one also.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
15. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
1 - 3 of 3 Posts
