"Although the Elise/Exige powertrain is built to close tolerances using modern technology the progressive and sympathetic running-in (or bedding-in) of a new engine and transmission....Failure to comply with the following running-in provisions will invalidate the terms of the vehicle warranty.
Being too sympatheic will not allow the piston rings to bed in properly. For the first 600 miles (1,000 kilometres) use no more than moderate throttle openings (about half the available accelerator pedal travel) and do not run the engine continuously as speeds over 4,500rpm. Occasional short bursts at wider throttle openings and higher rpm will be beneficial... do not let the engine labour in too high a gear...
After 600 miles or 1,000 kilometres have been covered, full throttle and/or maximum rpm may be used for short periods but not until the 'After Sales' service has been carried out should full vehicle performance be exploited.
Servicing is generally every 9,000 miles (15,000 kilometres) or every 12 months. Under heavy use oil and filter needs to be changed every 4,500 miles (7,500 kilometres), inspect air cleaner at 9,000 miles (15,000 kilometres), inspect brake pads at 4,500 miles (7,500 kilometres)
