1 - 9 of 9 Posts
I've installed lug studs in my car since I take my wheels off a lot due to tracking, and the clearance between the recessed screw holes on the wheels and the thinnest 17mm sockets that I've found is still too low - it cracks and scratches the paint on my LSS wheels, especially on the rears where the holes are deeper.
So, for anyone else who's got LSS wheels and a stud conversion, what are you using for a socket, and does it clear the wheels?
Absolute power does what?
I had the same issue/worry at first - got a deep 17mm socket from Sears (Craftsman one) and it fits just fine in my LSS - even after I had them powdercoated (it's a bit tighter now so I just start things slowly as to not scratch things up).
Try that one as it worked well for me - nothing special, just the 17mm deep they sell (I think mine is a 12 point not a 6 point). 6 should be better but that's not what I'm using...
-Ross
Hmm, odd. I'm also using the sears one since it fits best. My wheels are painted from the factory, and it scrapes those. It fits great in the unpainted, older ones I bought from someone else. Thanks.
The only thing I can think then is the painted wheels just have too thick of a coating on them and it's making the hole narrower. Of course that doesn't really help you does it? :)
I suppose you could either have a shop grind the socket a bit (but if I remember it's a pretty thin walled socket already) or have someone grind out the wheels in such a way that it looks good but is thinner. I was pleasantly surprised that mine still fit after powdercoating - it's a tight fit but I've never minded a tight fit ;-)
-Ross
i had the same problem with my black LSS wheels. i ended up buying some muteki 12x1.5 open ended lug nuts from ebay. they came with a thin walled keyed socket (much thinner than the thinnest 6/12pt socket i could find anywhere). been hammering them off and on all season without any problems, and no more rubbing on the wheel paint!
1 - 9 of 9 Posts
