1 - 3 of 3 Posts
1971 lotus s2 europa carb problem?
Hi all I have a 1971 s2 lotus Europa witha 1545cc enginerunning a dcoe weber 45 carb I have set the carb up andthe timimng is at 8 degrees BTDC and the engine starts and idles fine but at 2000 rpm there seems to be a large flat spot.I you slowly increase the rpm there is no problem but if you try to accelerate hard the engine will stumble at around 2000 rpm but above 2200rpm the engineis good itwillrevallthe way up to max with no problems is only at 2000 rpm. Please help
have you posted on the Yahoo group? that group is fantastic with help and direction.
they have made my experience with my 71, S2 much more manageable.
1 - 3 of 3 Posts
