1 - 14 of 14 Posts
My seats need to be redone. I took a quick look where they bolt in (thinking of putting in my sparco evo 2's while waiting) and noticed it looks like the bolt is welded? Any tricks to taking the stock seats out?
thanks,
apologies in advance, lotus and carbs are new to me, so i'm going to have a million little questions...
· Wingless Wonder
1988 Esprit Turbo, 2005 Elise BOE Supercharged
The Esprit seats are narrow. Don't be surprised if your Sparcos don't fit. :eek:
But yeah, only four bolts underneath. The topside bolts are welded to the rails.
Don't lose the fat fender washers underneath, they are needed to spread the loads on the fiberglass body.
· Banned
Hi.
If you go on youtube and lookup-WHEELER DEALERS, Lotus- you can see how Ed took the seats out.
I believe you're seeing some adhesive (not weld) applied to the bolt as others have easily removed the nuts from there.
It's the bolt inside the car. I had no idea they were removed from the bottom... Will check out the bottom and see if I can get the sparco's in temporarily while the stock get recovered...
I'm using the Sparco Evo seat in my V8 for track use (better support). In case it's helpful there is a posting on my setup here: http://www.lotustalk.com/forums/1829404-post10.html
Knut
· Wingless Wonder
Seats came out easy peasy, but the Sparco Evo 2's didn't fit. Imagine that. Front is too wide.
Maybe you could have one seat done at a time. Just swap seat positions so you can still drive it while the other one is being restored.
mpesik - do you happen to have a link to that video? It seems the DiscoveryTV channel on YouTube only provides videos 1-4 and if you want to watch the rest, it's forbidden for folks in the US due to copyright violations.
I've got a couple of seats in very good condition about that year, black with red pleated leather, if your intrested please PM me and I'll send you some pictures. You will need to use your existing seat rails.
Robert
Sparco has several seats in the Evo line for different size occupants. I don't recall off the top of my head which one I selected but I'm sure it is indicated in the thread I pointed to earlier. Did you select the same size and it doesn't fit (due to the earlier car being narrower) or did you select a different wider one and it doesn't fit because the seat is wider (but the space is the same)? There is a detailed seat sizing chart on the Sparco web site with all the dimensions of all the different seats indicated.
Knut
Discussion Starter · #14 ·
Knut
I have a pair of Sparco Evo 2 Plus for my other car and I took the seat out of the Esprit and got the Sparco in, but the front end is too wide and the rails won't go down to the floor to bolt down.
1 - 14 of 14 Posts
