es the paint is going to be durable. I have a friend that has a body shop and he mixed me a little paint and added a something to it he paints wheels with. I also cleared and waxed it after I was done. The number's are done in model paint.Most people fill the numbers with paint and leave the ball aluminum colored, but I like this better. What did you use to paint the ball? Is it durable enough to not wear?
I will show install pics when I finish my new Black and Gold LSS wheels. So stay tuned and I will post pics. Thanks:coolnana:Looks great! Installed photos please![]()
black ball! I want to do that too, but with all the characters in red.
Did you sand the ball down a bit before painting?
Sure would! All I used is my sm. touch up gun. Vary easy mod, anyone can do. Have at it and good luck!:coolnana:I love it! It would look great on my non 72D Starlight black.
I talked with Mike (The buddy that has the body shop) and he said that a off the shelf wheel (spray) panit would work also. That is for though's that would reather have a solid color, no flake in the faint. Said it can be bought in black, red, gray, yellow and even gold at about any auto store. Good Luck and let's see some painted balls (shift!!!):coolnana:Most people fill the numbers with paint and leave the ball aluminum colored, but I like this better. What did you use to paint the ball? Is it durable enough to not wear?
Last time I tried to get mine off it was stuck, but maybe I'll try it again...[/QUOTE
I am sure you know about the set screw at the back of the knob, but just thought I would say something about it. I have taken mine off, to see how hard it was and all I had to do once I loosened to set screw was twist it. Good luck and hope you get it!:nanner:
Yeah, I loosened the set screw, but evidently the ball's threads are goofed up. I can try squirting some penetrating oil up in the threads. Before this, I had no good reason to pull the ball off.Last time I tried to get mine off it was stuck, but maybe I'll try it again...[/QUOTE
