1 - 6 of 6 Posts
I'm planing to replace the yamaha mirrors with RACETECH GP2/F3 (Stem = 125mm (20x105)) Product Detail
It would be the same design and same manufacter like the center mirror. I can imagine that it looks very well, but is it strong as well? Do I need to take apart the side panels to reach the mirror-bolts?
There are two ways to get to the bolts that hold on the side mirrors:
1) Remove the side panel
or
2) Drill holes in the inner panel large enough to access the bolts.
I haven't tried #2
or
I haven't tried #2
Thanks apk919, I checked the mounting again and I now thinking that it should be possible with just taking off a few bolts of the clam and side panels around the mirrors. Than there should be enough space to catch the bolts with a open wrench and a magnet :panic:.
I could imagine, that the vents to the aircooler could work a little better with these mirrors. But this is just a assumption, not knowing if it's even measurable.
I just ordered the mirrors. I can send some pictures if somebody is interested. (only in case I get it mounted quickly and it's looking nice as well :))
Be keen to see a picture when you have them installed .
Where did you purchase them from ? Racetech direct ?
The workshop right next to me tries to order it at racetech, but they've nothing heard of them today. Have just to wait a couple days.
I've seen it at demon tweeks, JJC and even at british ebay!
Two little disadvantages it could have: Setting the height (angle) of the mirror is possible with the mounting bolts only (as much as i see). But setting it once it should work. Otherwise apk919's suggestion #2 becomes effective :)! The other thing is, that the yamaha mirror is fixed with two bolts, let on hole visible after installation. Don't know what to do with it?!
Maybe cover the hole with some vinyl "wrap" of the appropriate color??
What color is your car?
1 - 6 of 6 Posts
