1 - 3 of 3 Posts
Previous owners and road rash have nailed valence (component with fog lights) below bumper and lower fiberlass/rubber spoiler.
Have tried to find steps to take off valence, but just find bumper directions and that appears to be PIA.
What are steps for taking off jst valence and spoiler so I can get them repaired?
Thanx
Mark
Mark,
Remove the following: spoiler lip, undertrays, horn, fog lights. You will then need to remove several 10mm nuts around the upper edge of the valance from under the car (8 total I think). IIRC, there is one on each front corner that you will need to use a long socket extension through a fairly small access hole to reach the nuts. The nuts are on threaded stud plates so no need to hold anything from the top side. There are also a couple of phillips head screws holding the mesh grille in the front.
Then carefully remove the valance.
Hope that helps.
Jim
1 - 3 of 3 Posts
