I have to believe that this is a common problem but I can't find a single thread - so maybe not. As I was rolling the window up the other day I heard something crack/break/snap and then the window wouldn't roll up. When attempting to roll it down, thinking it was jammed, it fell instantly down into the door cavity. Fortunately it doesn't appear to have broken = $$$$$
I removed the door panel tonight and honestly can't see a damn thing wrong. The window moves up and down manually but not all the way up. The motor has no effect and only works for a second in either direction. Sounds jammed or something. I found some cracked broken plastic in the bottom of the door that I think may be related or may be from the crappy door handle plastic that disintegrated into the cavity as well, not positive. The cable that runs around the pulley seems loose, but again, hard to tell. Am I headed to the stealership or has anyone seen this before???
