1 - 8 of 8 Posts
Hi guys,
I'm relatively new. I just bought a 2005 Elise with a Forced Fed 275 kit. Just wanted to introduce myself. Anyone else skip N/A and go straight for a boosted Elige?
** The Enforcer **
Multiple accounts are not allowed. Please explain this or both accounts will be locked.
San
Welcome to the club! You need to post some pics with your intro man! Let her shine, lol.
Force Fed 275....awesome. As for skipping, I waited until I was out of warranty and paid off, then went S/C'ed. Loved the jump in power.
These are brilliant cars.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 -35 minutes after coolant has reached full operating temp before engaging cam switchover.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
15. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Congrats and welcome! Share some pics!
Discussion Starter · #8 ·
Stock: “Excuse me”
5. Transmission:
And, use:
How to Search:
Lots of helpful tips here!! Thanks! Hope you guys can see the pictures!
1 - 8 of 8 Posts
