1 - 6 of 6 Posts
I recently joined Lotus Talk. I live in Sedona,
Arizona and was wondering if any Lotus owner knew of a 5 star Lotus mechanic in my area ?
Thanks !
Wingless Wonder
1988 Esprit Turbo
Howdy! Welcome to LotusTalk.
Administrator
Welcome to LT! I'm sure someone living in your area will chime in with recommendations.
These are brilliant cars.
You'll have lots of fun.
Congrats!
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
Welcome! You live in a Beautiful area!!! Please post some pictures with some good backdrops.
I'm a graduate of Embry-Riddle there in Prescott. That would be an awesome place to own a Lotus. There's no shortage of curvy mountain roads.
1 - 6 of 6 Posts
