1 - 12 of 12 Posts
Hmmmm... thanks.
Anyone have any idea what the heck this thing is doing riveted to the inside of my wheel well liner???
Could the dealer have moved it when the pulled the clam for my oil cooler fitting? :shrug: There appears to be freshly drilled drain holes in the liner...
I could have sworn I had all my wheel well liners out before to inspect... but heck, I can't pull my liner with this stuck to it!!! :confused:
Looks to small for ballast but possible.
I believe that's the new relay for the ac/fan system. Some cars' ecu's would malfunction if the ac was on while you were driving. This caused engine cut-out or downright stalls at speed. I believe there was a service bulletin to fix it but I'm too lazy to search right now. Although, if i remember correctly, the service bulletin says to install it on the passenger side... ::shrug::
EDIT. found it. http://www.lotustalk.com/forums/f157/exige-s-engine-cutout-c-relay-information-66770/
Discussion Starter · #9 ·
Holy cow Butters... that has to be it. It looks just like that... same location. Weird cause it's an N/A 2005 Elise. Maybe the orignal owner had a problem this fixed or the dealership was just proactive on service bulletins.
Definitely not an HID ballast.
Thanks to all that posted.
1 - 12 of 12 Posts
