1 - 4 of 4 Posts
So my Ac was working fine until it just started blowing hot air then I turned it off and turned it back on and it was oils blow cold again until it started blowing hot again. I checked the pressures and the high side is 150 and the low side is pegged all the way. Any insight would be great.
Here's a start:
Reactions: zeo
Its the evaporator coil frezing up. The permanent solution is to have the electronic thermostat installed at the coil.
Michael
1 - 4 of 4 Posts
