1 - 8 of 8 Posts
Hi all
I am looking a purchasing a 2006 Elise that has 15k miles. A local lotus shop (not a dealer) did a PPI. They commented that the 3 gear syncro was sticky and suggested a gear box flush. Does any one have any thoughts on this. Unfortunately the vehicle is cross country from me and I have not personally driven it.
07 Exige S
Since you just throwing it out there. If everything else checks out or is indicative of a solid unit. I would prob continue considering it. I have done a ton of modifications to help shifting, to include better fluids. I still think the syncros are just not great in these cars. I learn how fast each gear wants to be engaged and I accept it as a mechanical limitation. I simply shift slower in some gears.. good fluids and better, more solid action will certainly be noticeable improvements and as the addage goes you can spend as much and make the action as good as you want. I would flush it yourself if mechanically inclined or have your local persons get on it. will give you time to decide what fluids etc you want. I loved the MT-90, Synchomesh coctail immensely, but I just go with Motus 300 something now. Either are worlds better than the oem stuff most likely in there right now. Oh yeah, and it's very easy to do... You could get it done first time you have it on ramps with shear panel off. ( Just make certain you have the fill plug off before opening the drain plug...)
Thank you for your reply. The rest of the car checks out fine.
See #5
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need...
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
My pleasure. Good luck.
Vendor
IMHO, the 2006 is one of the best years to get if you want a car to do some things later. The ECU is the newer style with DBW, which Fastworks has a bit better control on for later supercharging. The bumperettes in later versions aren't there. Sticky synchro doesn't bother me too much unless that 15k miles is ALL track, it probably gets resolved with fluid. If not, transmissions can be fixed.
Discussion Starter · #8 ·
Thank you for the reply
1 - 8 of 8 Posts
