1 - 7 of 7 Posts
Hello
What are the things/issues/recalls to look for in a 2007 Elise?
Suspension wise is there anything to replace?
Thanks
Not sure what your question is. Cars wear out bushings, etc at different rates, depending on how driven, quality of roads, etc.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
15. Visit the Uber Thread
**Elise/Exige Uberpost READ THIS. Everything you need to know is in here**
Plus, “How to bleed brakes”:
How to Bleed Brakes
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
2005 Elise LSS Saffron Yellow
Hello
Thanks
Suspension stuff is a miles-not-years thing on any car. Most of the suspension modding done by people here has been done to better optimize the car for some particular purpose, not because something was worn out. If your question is asking 'are there neat go-fast suspension bits available?' the answer is yes - quite a lot.
I am looking at this 2008 yellow elise, its from an authorized dealer in birmingham, MI. The guy i spoke to said the front cluster
Was replaced and said the mileage was consistent with cars mileage.... Name of dealer is AUTO EUROPE SALES, in Birmingham, Michigan. Car has clear title.
Thanks
these are the dealers NOTES. this is an authorized lotus dealer: I am curious when i spoke to the salesguy he said the "CLUSTER" was REPLACED but odometer is consistent w/cars mileage.... Do I walk ???
"2008 Elise SC, Saffron Yellow, Hardtop and Touring. Carfax shows mileage discrepancy, we did the odometer change and have the paper trail to verify mileage. This is a 2 owner car despite the Carfax, note when you review it is the same owner going between Florida and Michigan. We have serviced this car since June of 2011 with over $14K spent on service and maintenance . No excuse car, no track time, mature ownership, no damage, great Lotus color. We have inspected this car prior to sale and it is ready to go. Leather Interior Surface, Carpeted Floor Mats, HID Headlamps, Premium Sound, Rear Spoiler, Rear Spoiler, Tire Pressure Monitor - "
2005 Lotus Elise
It is not uncommon for the cluster to be replaced, And is not a big deal. When the dealer replaces the cluster, they put a sticker on the driver door sill indicating the mileage at which it was replaced. Ask for a picture of that sticker.
I believe that typically the title does not need to be branded. when the cluster is replaced, the total mileage is the odometer reading plus the mileage at which the odometer was replaced and set to zero (mileage on the sticker). I wonder if in some cases it’s just because somebody didn’t know what they were doing, and and checked “ not actual mileage“ on a title application. My 2005 Elise has the same situation: a sticker indicating the odometer was replaced, and around the same time, Carfax shows it having a “ not actual mileage“ title brand. unfortunately, even though I have a high degree of confidence that I know the actual mileage, once you have a branded title, the DMV won’t let you switch it back (at least not in Indiana or Florida).
1 - 7 of 7 Posts
