Thanks! Here's one of the scoops...Looks good!
Well, it took a while for me to find the mounting bracket for my flow meter, but I took a quick set of max and average flow readings for a short drive.
The max reading was 1100 fpm at about 80mph. Based on the calibration and data from this post: http://www.lotustalk.com/forums/f15...-air-flow-study-59117/index4.html#post1059881, that implies a flow of around 715 cfm. With just fettling and the Cup roof, only about 275 cfm flowed through the I/C. So if this data is accurate, I've increased the flow through my intercooler 2.6x, over a fettled clam with a Cup roof only.
That's very encouraging, but I'll need to run a full test, comparable to the original tests. Also, a took a quick infrared temp reading, after I'd shut the engine off. There was still a 20˚ difference across the I/C, even though no air had been flowing for at least a minute.
More to come...
Thanks... those were the numbers I was looking at too... at first, I wanted to plumb the ducts directly into the I/C shroud, but there are two problems with that... 1) there's very little room to work with on the shroud (the I/C on the Cup cars has even <b>less</b> room), and 2) if I change intercoolers, I have to redo the plumbing.Cool! Looks like you've done what I've been "wanting" to do for a while, but haven't found the time.
I wanted to put the 3" inlets into the duct that mounts to the I/C, but never thought about the duct from the roof.
So you are maximizing the flow...
I estimate the input area on the stock Exige S roof to be 1.5" x 8" = 12 in^2
Adding two 3" ducts = 14.175 ^2 additional inlet area...
So you've more than doubled the potential inlet area...
Will you consider to make this part with CF to replace the whole OEM parts and sale it to us?More to come...
How did you get the mounts into the plastic duct from the roof? Were you able to remove it? I'm wondering how it is attached....Thanks... those were the numbers I was looking at too... at first, I wanted to plumb the ducts directly into the I/C shroud, but there are two problems with that... 1) there's very little room to work with on the shroud (the I/C on the Cup cars has even <b>less</b> room), and 2) if I change intercoolers, I have to redo the plumbing.
Unfortunately I can't manufacturer parts in CF (or even plastic), so no... sorry.Will you consider to make this part with CF to replace the whole OEM parts and sale it to us?
My roof duct was already cracked badly... probably from the engine rotating on the soft OEM mounts and exerting force on it. I knew I'd have to repair the cracks anyway, so I just used a Dremel to connect the cracks and remove part of the roof duct. I originally tried to get the whole piece to come out by wedging a putty knife under the duct, but it wouldn't budge.How did you get the mounts into the plastic duct from the roof? Were you able to remove it? I'm wondering how it is attached....
Once the piece was out, I trimmed a set of NACA ducts to fit the contour of the roof duct, then cut holes out of the duct and epoxied the NACA ducts in place. I used RTV sealant to make sure the fittings were air tight. Then I epoxied the roof duct back in place, and resealed any air leaks with RTV.
A few pictures...
1) At left: original duct piece, center: roof duct with cut outs and trimmed NACA ducts, right: high temperature silicone brake ducting
2) Roof duct after supplemental ducts were epoxied and sealed with RTV
I'm sorry if anyone's gotten the idea that I'm planning selling this as a kit... I'm just another Lotus enthusiast; but I'd be happy to share any information that would help others put something like this together on their own (i.e. parts sources, photos, procedures, etc).wow! looks good and great improvement. i hope you will be able to sell us a similar thing in the future at a reasonable cost. good luck!
Given the space constraints, I tried to angle the ducts in the direction of the airflow as much as possible. There's very little room between the duct and the rear window glass...Im just wondering if those ducts were re angled to allow the airflow pointed through the ic instead of into the duct may have a better effect?
maybe more efficient and greater air speed through it which may have the effect of dragging air through the slot on the roof faster?
Thanks! Here are a few more pics:Great job, that's exactly what I had thought and planned for my next upgrade...
Yeah, I can't imagine being able to get the roof duct out in one piece without removing the rear clam. If anyone has any experience with removing the duct, feel free to chime in! On the other hand, a brand new roof duct is only $82 or so from Lotus Garage... Lotus Garage - Chargecooler & DuctingDang, I was hoping that piece would just unbolt off...
Nothing is easy in regard to more airflow to the I/C
Yes, I have a track day Tuesday, and I plan to log IAT, ECT, and spark advance over a number of laps with both the side scoops blocked off, and open. I seriously doubt there is any backflow through the roof scoop; because of the bottleneck, it's very likely that the pressure inside the roof scoop is higher than the pressure in the roof duct... and air will not flow against a pressure gradient in that case.apk, are you planning to log temperature? how about blocking off the roof opening? (could there be some backflow out through the roof opening?)
