I think this is a full software download from innovate. It's called Logworks. Program doesn't allow an export to excel and I dont want to copy just a section of the graph, there's about 20mins of data.
Support :: Innovate Motorsports
For those interested in data logged; download, install, the above in order to view the data file. PM me your email if interested, the file type is invalid for attachment here.
Look at session 1&3, 2 was an accident. Session 1 is upon engine start to warmed up. Session 3 includes highway driving, ending with semi traffic and parking lot.
TC4_2 is the temp at Cup roof scoop entrance.
TC4_3 is the inlet side temps
All other parameters self explanatory.
Dont pay attention to AFR, my sensor needs to be recalibrated.
I did another run tonight that was accidentally deleted, 2nd gear rolling start redlining thru 4th to 8k rpm to 180km/hr, twice. Inlet temps went up to 80C+ but drop quickly post hard running, outlet temps never crossing 60C mark, dropping slower than inlet IAT did to mean. For the most part IAT temps range in high mid 40Cs to 58Cs when running normally. Will be interesting to see stock IC and RLS+ fans result.
Ambient temps high 20's. TC4_2 hood temps were consitant with this prior to run and raised to high 30C's, and stayed around there regardless whether car was moving or still. Marginally down 1-2C at higher speeds. My guess this has to do with hot air from radiator which heats up surface near roof entrance where thermocouple probe is located. Since it also senses radiant, this is prob why.
When I get the chance, will do the same with a stock IC only. then RLS with Spal fans arrived today... and another data set with fans + RLS IC + heat shield (between engine and IC).
Note: car has large alum rad., low temp thermo RLS IC, WR header/decat, Sard stock airbox highflow filter, airboxsnorkel delete, Ti TWR muffler.
