1 - 8 of 8 Posts
This is an well prepared, low mile, naturally aspirated, IPS, Evora. The donor car had only 3,100 miles on it before it was built into a track specific car. . This Evora is very fast, beautifully balanced, easy and fun to drive. It was built with durability and reliability in mind and should provide many miles of fun with regular maintenance like oil changes. Before it was converted to a track car it was vandalized with only superficial cosmetic damage, no accidents. But, now has a salvage title, and like many track cars will be sold with a Bill of Sale. Its not street legal so would make a great track day car, or could be used in Time Attack, Time Trials, or autocross. It just had a complete fluid change, new wheel studs, safety inspection, and nut and bolt by TruSpeed at The Thermal Club. Car is located in Southern California.
Just bought another car and the Evora needs to find a new home!
Asking $34,500 OBO
Body/Exterior
  • Evora 400 Front Bumper
  • GRP Evora 400 Front Splitter – Aluminum
  • GT4 Style Door Hinge Covers
  • GT4 Vented Top Access Panel
  • GRP Carbon Fiber Side Skirts
  • Hethelsport 410 Type Rear Hatch with Custom Wing Setup
  • Modified OEM Rear Hatch for Chassis Mounted Wing
  • GT4 Side Air Scoops
  • Custom GT4 Style Rear Diffuser
  • Modified Rear Bumper
  • Dzus Fastener Front Clamshell, Rear Clamshell, Rear Bumper
  • Aerocatch latches on Front Clamshell
  • Painted Using DipYourCar plastidip – Anthracite Gray
  • GRP Tail Lights
  • Various Sticker – Good for 5hp atleast.
Wheels/Tires
  • Enkei PF01 Wheels 18x8.5 +48 Front, 18x9.5 +45 Rear - 2 Sets, 1 Candy Red, 1 Bronze
  • Hankook z214 DOT Race Slicks 240/640R18 Front 260/660R18 C51 Compound
Suspension
  • Ohlins TTX36 Dampers – Factory GT4 Kit with Upper mounting brackets
  • GT4 High Camber/Castor Control Arms , Upper & Lower, Front & Rear
  • Eibach GT4 spec Sway Bars, Front & Rear with matching bushings
  • Spitfire Rear Tow Links
Brakes
  • DBA 5000 Two Piece front rotors
  • DBA 4000 One piece rear rotors
  • Cobalt Friction Brake Pads - XR2 front Compound, XR3 Rear compound
  • BOE Brake Bias Cage Kit
  • Tilton Double Master Cylinders – Spec’d by VSA
  • Braided Stainless Lines from masters to ABS Unit -4 per VSA
  • AIM Data Brake Pressor sensors mounted inline using BOE manifolds
Engine
  • Innovative Rear Engine/Trans Mount
  • BOE Camshaft Package
  • BOE Tuned ECU
  • BOE Cold Air Intake kit
  • BOE Long tube headers
  • VSA Custom rear exhaust section – 2 mufflers w/Laguna Pipe/muffler
  • AIM Data Lambda AFR sensor/gauge
  • Custom Valve cover breather/catch can
  • Moroso Coolant tank
  • Moroso Baffled High cap. Oil sump
Cooling
  • GT4 High Cap Aluminum Radiator
  • Mishimoto Electric Fan Control Unit
  • Spal large single puller fan
  • Summit Racing Power Steering Cooler
  • Secondary OEM Oil Cooler on Pass side for aux trans cooler
  • Laminova Medium size Engine oil cooler
  • AIM Transmission Temp Sensor in Oil Sump
  • AIM Engine Oil Temp Sensor in oil sump
  • AIM Pressure Sensor on braided line to side of engine block
Interior
  • Gutted Interior – Dash is only OEM Piece left
  • GT4 Carbon Fiber dash fascia
  • Sparco Evo II Seats
  • Sparco Seat Mounts
  • Sparco Belts – Hans 6pt on Driver Side, Basic 4pt on Passenger side
  • Custom Harness Bar
  • OMP Fire System - Electronic activated
  • Shorai Battery in sealed battery box behind driver seat – W/Electric cutoff
  • MMP Magnetically assisted paddle shifters
  • Works Bell Quick Release for Steering Wheel Paddles
  • Sparco Steering wheel adapter
  • Sparco Suede steering wheel
  • Tilton Brake Bias Adjustment knob
  • AIM MXS Strada dash with data hub/expansion channels
  • AIM GPS Receiver
  • Electrical Cutoff switch on dash
  • Cool Shirt Control unit with custom mount
  • Cool shirt Ice box mount
  • Custom cool shirt ice box setup with lines
  • GT4 Door Card with pull strap handles
  • Electric windows and door locks retained
  • Electric Radiator fan bypass switch
  • Heating/AC Deleted
Fluids
  • Redline 0w40 Engine Oil
  • Redline D6 ATF Fluid
  • Redline Brake Fluid
  • Distilled Water w/ 3/4 Bottle of water wetter
  • Redline power steering fluid
1257284
1257285
1257286
1257287
1257288
1257289
1257290
1257291
1257292
@Bzurcher Please post a price. Although it can be unrealistic OBO (exp. $100K OBO) you still need to post a price. Thanks and GLWS.
San
Per the last two post requests, I have listed an asking price for the Evora in the original post..
Hey are you in any chance interested in parting out and selling Ohlins TTX-36? I know its a long shot... but I thought least I can do is ask...
Thanks for asking about parting out the car but I’m not interested in parting it out. There is an offer pending.
1 - 8 of 8 Posts
