1 - 4 of 4 Posts
I need some guidance. In checking codes it appears that I have a bad coolant temp sensor.
my issue is where is it located? Has anyone done this job and can share a picture or some knowledge I would appreciate it.
Thanks
Chris in Miami
2013 Evora S
Looks like right above the flywheel / flexplate, and below the throttle body, 19mm for the sensor
Font Parallel Drawing Pattern Diagram
Dr Pocky,
Thank You for the Diagram!!!!! I appreciate you taking the time to upload it and answer my question. Looks like I can change this from the top if I remove the air filter. I will be able to see it.
Thanks Again , i’ll post my notes here as I tackle the project.
Chris in Miami
Yellow Evora
1 - 4 of 4 Posts
