1 - 10 of 10 Posts
Includes 2 sets, you need to re-use the stock screw. Comes with 2 washers/Shims.
Unscrew the stock broken piece, and replace with a more flexible and non-brittle unit.
$10 plus ship.
1272357
1272355
Can you show a picture of it installed? Definitely interested, but mine has been broken since before about the car, so I actually don't know where it goes.
Sure! It is circled here:
1272356
Look in the engine compartment side... there should be a Philips screw. If not I can provide one. Thanks!
Reactions: RapidLotus
HHmmm, have you considered making the clips that hold the ABS wire to the brake line? The flexible, not brittle has an appeal.
Sure! I Can make anything you need.
2005 Lotus Elise
I was able to get a replacement so no longer need it, but another part that's impossible to get is the front turn signals, not sure if that's something that can be 3D printed, but I'm sure you would find significant demand for that if you could.
The front turn signals are now available from Lotus vendors.
Later,
Eldon
2005 Lotus Elise
I found this link:
Parent thread #57: Elise turn indicators?
Discussion Starter #10
bump
1 - 10 of 10 Posts
