1 - 18 of 18 Posts
2014 Evora S
Hi All,
I know the topic of Sparco seat comfort has been covered to some degree. In my fairly active search for an Evora 400, I test drove one recently and found the seats more like an economy airline seat, that is, severely lacking in lumbar support. Granted could be partly due to my height (5'7") and body shape, and being a bit spoiled by BMW sport seats for many years, but they were really below my expectations/hopes.
I really want to like this car and not opposed to creative approaches to addressing seat comfort, but I'd like to know if the Evora GT seats are identical to those of the 400. The GT is out of my price range but still curious if any changes were made.
Appreciate any shared knowledge.
Howard
2014 Evora S
The S1 Recaro’s are brilliant. Wonder if a set could be retrofitted?
I've done a fair amount of searching on this as I struggle with S model w/better seats vs 400 w/lesser seats. THIS is the closest thread I've seen to fitting the Recaros to the 400.
My main issue with the Sparco's is the shape and lumbar support but more seem to have an issue with the height. In my short test drive I sensed being 'on' rather than 'in' the seats but at 5'7" it's not a huge issue for me.
Its as simkple as 4 bolts. Go to Recaro directly and order a set.
2017 Lotus Evora 400 manual, 2009 Rossion Q1, 2019 Jeep Cherokee Trailhawk
Same exact seats are used in the GT as the 400's.
They just have a different upholstery design and the carbon backs.
Really? Not doubting you because you'd know far more than I on this, but just surprised that in my short GT test drive they did seem different (slightly higher/firmer) as others have said as well. Is the cushioning thicker?
@DoubleH , I can understand what you're saying but personally they're very comfortable for me and I'm about the same height. Perhaps the design is intended to save weight compared to other seats?
2017 Evora 400
The 400 seats suffer from the issue where the bolster becomes untucked. Has something been done the apparently same Sparco seats in the GT to stop this from happening?
Vendor
I suppose there is a chance they changed the foam density on the seats between the two but they are identical.
I've had my personal GT side by side with a local 400 and we were comparing the seats with and without the rear spacer removed etc.
Loves to talk
Something's wrong there. The clips fixed mine perfectly but it took two tries. First go round they cocked it up. I had the dealer do it as it was under warranty. It is a 100% fix so I'd stay on the dealer or find an upholstery shop that will work with you. The seat needs to come out of the car for the clips to be installed properly.
yup, first time they just tried glue, second time seats out and clipped. 6 months later, a little untucked on both seats on the outside edge. front held ok after the clips.
2014 Evora S
Discussion Starter · #16 · (Edited)
OP here. This thread took some very useful turns, appreciate all the info.
Drove an '18 400 today. In a generous 20-minute drive my lower back came out a bit sore. Sitting with good posture in the seat left 2-3" of air between my lower back and the seat. Leaning the seat back helped but not entirely. Sat in a GT as well, seats were a bit tighter width-wise in a good way and maybe felt slightly different in the lumbar area, hard to tell. I don't think they are 100% identical but GT is out of my price range anyway.
Loved everything else about the 400 so the seats wouldn't keep me from buying one, but definitely an issue that will need some kind of attention.
Its as simple as 4 bolts. Go to Recaro directly and order a set.
This thread says otherwise. I think airbag light would be an issue as well.
2014 Evora S
Discussion Starter · #18 ·
Saw that and DM’d the author. Sportsters will require some additional rail work but good to know it’s possible without -too- much trouble
1 - 18 of 18 Posts
