1 - 2 of 2 Posts
Hi all. im new, extremely frustrated, and a little sad too. i have a 65 super 7 with a 1600 x-flow that was recently rebuilt. engine runs like a champ but my clutch wont disengage when the pedal is fully depressed. if i let the pedal back about 1/16th of an inch it works just fine. what the hell is going on? its got a new clutch, throwout bearing, plate.....everything. im almost positive theres no air in the hyd. system. does ANYONE have an idea?
Hi and Welcome!
It sounds like your clutch adjustment is off. Proper clutch pedal free travel is critical -- and fortunately easy to adjust. It is a mechanical system, though, and will not adjust automatically like modern manual transmission equipped cars.
You need about an inch of free travel at the "top" of the pedal--i.e., when you first depress the clutch pedal there should be essentially no resistance for about the first inch of movement.
The adjustment is at a push rod that runs between the slave cylinder and the TO bearing release fork arm. The rod is threaded, and a jam nut sets the clearance between the rod and the fork. That clearance should be about 0.1 inches.
I can scan in a drawing later today if you need it.
1 - 2 of 2 Posts
