1 - 1 of 1 Posts
What is your First & Last name? Brian McGaha
What is your email? [email protected]
What is your phone number? : 2084400956
What is your City? : Boise
What is your State? : Idaho
What is your Zipcode? : 83712
Ad Description:
This isnt something Iam particularly happy about but rather than have this car sit in the garage for another year unused I would like to pass it along to someone who will see it gets used to the potential it was built for.
This currently is not a "must sell" but at this point I would say Iam the most motivated to sell I have been in over 3 years. Title is in hand. Please, if you are not a serious buyer or do not have access to the coin for a purchase of this magnitude do not waste our time.
I originally bought this car in 2002 out of Houston Texas. The chassis currently has 74K miles on it. In the fall of 2006 at an autox the car suffered a motor failure (spun rod bearing) as a result of a cracked external oil cooler from a cone. During the winter of '06-'07 I installed a new shortblock, oil/water pump, and a new Fluidyne oil cooler. Since the installation of the new shortblock the car has only received "break in" miles, short drives on weekends, etc. totalling 1000 miles. In Sept. 2006 the car did 614hp 590tq at 26psi on 114octane fuel. I rarely drove the car at anything over 20psi. For autox it couldnt effectively use much more than 420hp, and track days it would just get to hot over 18psi (typical). I will be selling the car with a conservative pump gas 14psi tune. It will be the responsibility of the buyer to get it tuned for anything higher.
Please take a look at the feature page on Steve Theodores Supra Hardtop Registry here: Brian McGaha's 1994 Supra T hardtop
Be advised as you read the story and mod list that parts have changed over the years. The mods listed on the registry page might not be exactly whats on the car now. The current mod list will appear below.
This car is currently set up for road racing, track days and autox, I would like it to stay that way. In the cars current condition I would not suggest driving it long distances due to alignment settings, type of tires, etc.
The bad- Car has a small powersteering leak. In 2005 I had all dents and dings removed, since then I have 1 ding on the hatch, and a small dent on the drivers side rear quater panel. Paint is a 7 out of 10. Buyers with the intent on using this car for what it was built for wont be worried about these paint imperfections anyways.
Asking price is $38,500!
Please try to send all questions and comments to my email: brianmcgaha @ gmail .com
ENGINE:
-2JZ-GTE OEM shortblock 1000miles
-OEM head with mild port work (West Coast Cylinder
Heads)
-Crower Ti valvetrain
-PTE 61mm turbo .58 a/r
-Boostlogic header, heat wrapped
-Powerhouse fuel rail
-6 lines from twin Supra fuel pumps
-850cc injectors
-SX Performance fuel regulator
-HKS Type-R FMIC
-HKS Racing type II BOV
-HKS "JDM" 5 bolt cam gears
-PWR radiator/Greddy 1.3 bar rad. cap
-TRD 160 degree thermostat
-TRD oil filler cap
-TRD motor + transmission mounts
Custom 4" SS exhaust (includes steel mid pipe with 4"
electronic cut out, switch located in ashtray location)
-Greddy accessory pulleys
-Boostlogic crank pulley
-Boostlogic turbo exhaust housing blanket
-Fluidyne external oil cooler/ remote filter/ Lexus V8 filter
(mounted in pass. side duct)
-RPS Carbon twin plate clutch/ flywheel combo/
(inspected 1000 miles ago, plenty of life left)
-Custom oil catch can/ radiator overflow tank
-Radiator cooling panel
SUSPENSION,BRAKES,WHEELS, and TIRES:
-OEM and Whiteline adjustable swaybars (car currently
only runs the OEM front bar, I will include both sets)
-TRD upper strut bar
-Penske 8100 dampers with 8300 Double adjustable
canisters (These are "no fooling around" shocks.
Canisters have the ability to be set up 3-way by
Penske. Dyno charts will be provided to buyer)
-Hypercoil springs (1000lbs F/ 800lbs R)
-Colorado Performance adj. Front control arms
-R2 poly suspension bushings
-Cryogenically frozen OEM brake rotors
-Perma-Cool powersteering fluid cooler (drivers side duct)
-TRD braided brake lines
-Hawk HPS pads/ Hawk Blues (HPS currently on car)
-Kinesis K20 18x10F/11.5R (will include shells to make
rears 17x11.5")
-Nitto NT-01 275/35F 315/30R tires 60% left
-Will include stock 17" front wheels with tires (these
have been a requirement by my local alignment shop)
ELECTRONICS:
-Gforce modified ECU
-HKS EVC EZ boost controller/HKS turbo timer (mounted
in dash panel left of steering wheel)
-HKS VPC
-A'pexi SAFC-II (mounted in drivers sunvisor)
-Greddy 52mm EGT, + fuel pressure
-Greddy 60mm H20 temp./ oil temp.,pressure,boost
-SP Engineering FMIC temp. monitor (ashtray location)
-FJO Wideband 02 with datalogging (readout in TRAC
button location)
-Racelogic Traction control
-Fields harness
-Dell C610 Latitude laptop for FJO/Racelogic
-Clarion ADX5655z cass./CD, and some speakers(he,he)
OTHER:
-TRD steering wheel
-Sparco aluminum pedals
-Odyssey battery relocated under car
-Polishing, powder coating, anodizing
-Custom cold air box
-Cobra lmola II seats
-Rear seat delete with carpet
-Custom passenger airbag guage panel (fabricated by
myself and holds the GReddy oil/water temp, and oil
press. guages)
-Autopower rollbar with door bars (door bars are not
powder coated to match the rollbar)
-I/O port camera mount
-M + R 5 point harnesses/ stock belts
-Custom OEM vented hood (fabricated by myself)
-Recently replaced carpet/floor mats (2003)
-New dash panels (2002)/ wheel bearings (2005)
-TRAC pump removed, wire tucking
-headlights painted black
-3150lbs.
Current pics will be sent to interested buyers via email.
1 - 1 of 1 Posts
