The high pressure relief valve in the air conditioning system of my 1988 Esprit Turbo "popped" after the car sat idling for a long time in high heat with high humidity dumping some of its coolant (RS-24) into atmosphere. I understand that after "popping" the valve is "weakened" -- it will now "pop" at a lower pressure. To raise the pressure release point back to "normal" I understand that the valve needs to be "tightened". How does one go about tightening the high pressure relief valve? Alternatively, where might I find a replacement valve?
Thanks,
Mark
Thanks,
Mark
