1 - 16 of 16 Posts
After thinking for several years that I wanted an Elise but never having an opportunity to drive one, I finally got behind the wheel, found the experience to be exactly what I'd imagined, and bought a 2006. I've driven it 500+ miles in the last month and enjoyed every one. Last weekend I took it from Seattle to Portland for the Indycar Grand Prix and *really* had a good time on some rural roads in the outlying areas.
I've watched these on Bring A Trailer for a long time but was never too comfortable with a long-distance pre-purchase inspection, let alone no PPI. Being able to take a locally offered car to the Lotus dealer for a PPI was a big factor in deciding to buy. It basically sold itself during the test drive, though.
At 40K miles it's in good shape overall. The main issues are that there are holes cut into the diffuser for what must have at one point been an aftermarket exhaust (not visible from any human angle); the climate control blower works intermittently; and the 225 and 255 tires on 15" and 17" wheels are (according to the dealer) too wide and have resulted in some wear, and an intentional cutaway, on the wheel well liners. They do look pretty badass though. I assume that was a setup for autox or track. I guess I'll probably look for some 16" and 17" wheels and reduce the width a bit.
It came with only one key/fob. I got a spare fob (and do have the PIN), but now need to track down a key blank. Not sure how to get the key code that I think will be needed to cut that spare -- just contact the local Lotus dealer, maybe?
Bottom line, I'm thrilled, and having fun diving into a new car domain.
Discussion Starter · #2 ·
Ah, my post has suddenly appeared! Looking forward to contributing to the board.
Welcome! Nice looking car, I have a silver one with a red interior also.
Your key issue can be easily solved at Ace hardware for less than $3. Like many items on these cars, the ignition switch was probably "borrowed" from another car brand. See the following post. https://www.lotustalk.com/forums/f95/where-can-one-buy-lotus-key-blanks-77126/ I have two 05' Elise and one used the newer blank and the other used the older so the changeover was in 2005. Yours probably uses the X168 blank. Slide the blank into your ignition prior to having them cut it. I only use the cheap Ace keys when I drive and save the original nice Lotus keys in a draw!
Reactions: cupric911
Your Lotus looks great. Love the color combo. Those wheels give it a nice aggressive stance. Too bad they are causing issues.
Ohh yeah, and Welcome! What turned you on to a "Lotus" and specifically and "Elise"?
Very nice!
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Discussion Starter · #7 ·
I do love the red interior!
Thanks for the welcome, and thanks for the tip on the key.
Discussion Starter · #8 ·
Thanks! I guess it's been a variety of factors. Several years ago I began vintage racing, which both exposed me to a lot more Lotus cars (mainly 11s, 23s, 7s, Elans, and Europas) and turned me into much more of a fan of racing generally and F1 particularly. I also discovered that I really enjoy driving lightweight and open cars. All of that combined has give me a real appreciation for Lotus, its history, and of course these modern marvels. It's a silly car that I certainly don't need but it's irrationally thrilling to own and drive!
Reactions: Crazy05
Congrats and welcome! Love the red interior. Share some rear shots please! I would like to see how the 255s look. Love that meaty look. Enjoy and drive safe!
Congrats on the car these are great little machines! Looks awesome in the color combo. Good to see another Seattlite on here! :)
Thanks for sharing your enthusiasm!
Discussion Starter · #12 ·
Here’s the only one I have at the moment. With bonus light pole!
Wow! Looks awesome. Thanks for sharing.
Congratulations on the car! I'm looking for my first Lotus as well and have been going back and forth with regards to buying sight unseen. Right now I'm hoping to find one locally and keeping an eye out on WireWheel (just based on the overwhelmingly positive reviews of them from these forums), so hopefully I get as lucky as you!
Great looking car!
I agree, that driving lightweight cars completely ruins you. Every other car feels like a fat pig and takes a lot of getting used to!
1 - 16 of 16 Posts
