1 - 11 of 11 Posts
Just finished prepping my car for a track day tomorrow, part of which was checking the toe links. Im running the sector111 RTV Brace with the Nord-lock lock washers and still the bolts were at less than 30ft pounds. So just and FYI, check those toe link bolts and don't think your covered because your running a sector111 brace.
On a side note the u-clamp that holds my exhaust on was also finger tight.. :) Might want to check that as well, expecially if you have an after market exhaust.
www.theapexinn.com
Hmmmmmmmm -eek-
Wow, can't get over how loose everything was.
this is important but ... how often we should check??
i did mine about November, how often u guys think we should look at if it's street-driven only?
I check mine at every oil change and/or when I have the access panel off for any other reason.
So far haven't been loose yet.
ok thx,,,but here's why i'm asking. i dont change synthetic oil very often and i dont take the access panel off much...so, is once a year sufficient? (street car) and in the absence of any signs/indications?
Forum Founder
Just my 2 cents, but for a street driven car, with less than 10,000 miles per year, once a year is enough. More often for autocrossed cars. Track cars should be checked before the event. Every event.
2008 Exige S240
It's my understanding that you must reapply loctite every time you tighten or loosen a bolt because it breaks the loctite bond. Therefore, if by checking you mean tightening the bolt using a torque wrench, then you may as well remove the bolt, reapply loctite and re-torque. Am I missing something?
What is the required torque on these bolts?
While I think it is better to remove the panel to check the torque...I have done mine without removing the panel. You can fit a long extension through the NACA ducts on the bottom of the car and get to the nuts.
thanks Randy...kinda what my sense was. I didnt wanna get in trouble with the Toe Link Police. :p
1 - 11 of 11 Posts
