1 - 20 of 21 Posts
The coin went where pictured.
Elise coin problem" media="(max-width: 640px)"> Elise coin problem" media="(max-width: 960px)"> Elise coin problem" media="(max-width: 1920px)">
It vibrates between 2 - 3.5k RPM and I can hear it slide back and forth sometimes.
I've tried using a magnet.
Anyone ever had this happen to them or know how I can get back there?
Also, what are the two wires on the floor used for?
Picture didn't load for me??? :shrug:
But if its under the seat you may have to remove the seats to get it out. Either that or try stopping really quickly and see if it will fly out.
Me either. Don't see any picture! So kinda hard to help.
www.theapexinn.com
Get one of those $2.00 36 inch grabber things at Pep Boys
i know, my photography and microsoft paint skills are great. I figured the picture would help
Get the car up to at least a 35mph cruising speed, then...
Throw the car into a hard left (slide it if you have to) and come to a stop! Ala - dukes of hazard style. The coin will dislodge and "plaster itself" against the outer rail sill, where you can now easily extract it by hand.
I'm actually only HALF kidding. I did this for a screw-driver head (exchangable tip) piece that fell down there once and it worked! Plus, you get to have a little driving fun, while doing it! :nanner:
Of course pick an abandoned parking lot, or some other similar such place before doing this. ;)
Either that or what Kestrel said - the flexible "grabby-tools" (I've got one with a red push button on the end of it that extends these little "claws"), if you can see it, or manipulate the head of something like this to it, will work.
The cables are for the seat belt female plug in. It send the signal that you are buckled in, or not, and it also close the circuit that would fire the "belt tensioner" in case of a collision.
Mats
maybe you can move it into reachable range with an air compressor?
Hmmm, maybe I'll try that on some of my own stuck coins I can't reach. lol
Put something really sticky at the opening, and drive around a parking lot until it sticks, or ends up close to the opening.
Try wrapping a piece of duct tape in a circle. Stick it in the hole. Drive and corner and hit the brake. If you manage to get the coin to slide into the duct tape, hopefully it will stick. Then remove the tape.
Those wires go to your seatbelt switch. If you don't reattach them when you put your seat back, you'll get a permanent seat belt light...
I disconnected mine and all it did was turn the annoying seatbelt buzzer permanently off - no seat belt light.
+1
Next time I remove my console I think I'll cover that opening with a card or something as a preventive measure. I dropped a "cupholder" screw in there once and held my breath 'till I could retrieve it with a small magnet in a stiff wire. Would not work with a coin though. At least until the gov starts making steel based coins again (as in 1943 pennies).
1 - 20 of 21 Posts
