1 - 7 of 7 Posts
Today and yesterday, this forum has taken minutes to load a page. Does anyone know why?
It is now taking 10 times longer for me to get my daily fix :p
Happy 4th everyone!!!
OK. This is the ONLY site that I am having trouble with though and I checked quite a few places before posting.
Thanks for the responses though.
Forum Founder
adamant...
please do a trace route
(if windows.)
Start
RUN
COMMAND
in DOS window-
tracert elisetalk.com
EDIT
Select All
Control C copy
Paste into your reply.
The tracert window may close when it's done, so you have to be quick. This should isolate where the problem is between you and the server.
Note, last night around 1:00, it was truly sucking, but now it is fixed.
You can redirect the output of any command line program to a file with '>'. For example:
tracert elisetalk.com > "c:\Documents and Settings\Andrew\My Documents\elisetalk_is_slow.txt"
Then open it in your favorite text editor (or notepad) and cut and paste normally. You can even type all that in the "Run..." dialog, and bypass the command prompt window completely if you like.
1 - 7 of 7 Posts
