I need to tap into the collective again. Kinda like the Borg.
’93 SE, the ABS light has been blinking for some time. I attempted to clean it without success. I soaked it several times in various solvents and the light continued to blink. Recently the ABS light went from blinking to constant. I used Epritmon to pull the codes. It’s showing a 36, no pump. I checked the fuses, OK. I pulled the ABS pump enable relay and jumped the pump terminals, it works. So what’s shutting down the pump??? Is there a reset on the ABS controller?? I have read through the ABS section in the manual and can’t find a reference to a reset.
I wanted a Lotus Marques switch but they are currently out of production. A friend turned me on to this switch (PSD25-0P-5800H | Electronic Pressure Switch: 290 to 5800 psi set point range). It looks plug and play. But I need to figure out why the pump is off now.
As always “resistance is futile” and thanks.
