1 - 4 of 4 Posts
My ac in my evora (2012 S) blows cold, airflow level is high when it first turns on, but after a few minutes, the sound will change in tone (it is just as loud) and the airflow level from the vents will decrease.
From that point for the rest of the drive, the airflow will increase and decrease. it almost sounds like its switching to defrost away from the vents but there is no air come from defrost vents near the front window
any suggestions?
I would check the filter- its not likely to be the sole cause of your problem but its relatively small and can get dirty and clogged up quite quickly and that will definitely result in inconsistent air flow.
In certain situations if the refrigerant level is low, it will cause icing of the evaporator, which can reduce airflow
thanks i will check filter and try to get refrigerant level checked
1 - 4 of 4 Posts
