1 - 8 of 8 Posts
I removed the front clam, then put it back on last month. Since then I've noticed a slight squeek when i turn right -- but only with the AC on. it definitely sounds like the AC that is making the noise. turning left, no problem/no noise. It did not do this before I removed the clam.
anyone have an idea what I might have done?
Thanks in advance!
Michael
Lotus Technical Bulletin recommends no turning right, only 3 left turns..... Kidding. I'm sure SirLotus will be around shortly to give you a much more useful answer.
Don
Not any easy thing to diagnose. If it really bothers you I would check for any steering interferences and possible refitting the clam.
Michael
sighhhh... i was hoping for a "you didn't do ____ dummy"... but refitting the clam will be what i will do. thanks Michael!!
I find it hard to imagine what steering component would interfere with the AC, "BUT" only while it is turned on.
BTW, you are not a "Dummy" :D
Michael
Discussion Starter · #7 ·
well I'm glad I'm not a dummy... at least not today. :p
yea -- it is definitely odd. maybe when the car shifts to the right (everything is pushed with G forces left) a hose or something gets pinched causing the noise i hear.
I don't have time to go diving into it, so I'll just drive it for a month or so. if it bugs me too much I'll tear it up some. :)
thanks again Sir and Raz. :)
Let us know if you solve this bizarre mystery :crazyeyes.
Michael
1 - 8 of 8 Posts
