1 - 12 of 12 Posts
Has anyone gotten their adaptive volume to work on the Touring stereo? It is suppossed to increase volume as you gain speed. Not sure it know how fast you're going, unless it has a speedo input (?!) or uses the tuning microphone. Either way, I'd like to use that feature. Otherwise I end up cranking the stereo down at every red light.
In the manual it states that this only works if this function was activated during installation. I'm guessing they were supposed to hook something up during install that they didn't becasue mine does not work either.
I dont think it is hooked up to anything.
I played around with the microphone and got my equilizer to sound a lot better. I also adjusted the frequencies and the gain or loss. It sounds great when the car isnt moving or if it has the roof on. Once you go above 40 mph with the rood off, it sounds like crap. I had the same problem with my MG.
Back in the 80's Lotus was working on white noise technology to cancel out unwanted sounds inside of the Esprits. Too bad the microphone cant figure out how to cancel out the wind noise. Maybe I should try to set the equalizer settings using the microphone when the car is going 70 with the roof of to see if it makes any improvement. It is hard to keep your eyes on the road and adjust the equilizer settings when you are driving. Maybe I need a sound engineer as a passenger.
I just wish the radio was hooked up to the light circuit so that when the lights were on the display would be dimmer - I hate bright displays at night as it tends to decrease my night vision...
If you have the touring radio, it has day and night settings that are adjustable. If you turn on your lights, it goes to the night setting.
elise doesnt have a speed sensor. so its not hooked up.
Nope. Standard radio. The manual for the radio shows a wire to control the brightness of the display (lights on/off), but apparently it's not hooked up.
This feature is one of the major things that I look for when I've had to install an aftermarket radio in a car...
Mine has this, but the car is younger than yours by a fair amount. Maybe you can pick up a newer base/touring radio from someone who is installing something bigger/bettter/heavier. :)
I'm actually pretty pleased with the one I got. The clock is either 12 or 24 hours, you can set it up to show you the time all the time, it plays MP3s if you burn them to a CD, you can get the display to match the color of the rest of the dash. (except for the "blue dot" button. Doesn't sound too great, but I assume thats the speakers/size of the car.
Re: speed sensor
elise seeker said:
whaddya mean it doesn't have a speed sensor? the mph display is based on what then??
This is what lotus sent me a while back.
Thankyou for your enquiry. This is what our guys had to say-;
The pulse signal from each of the four wheel speed sensors to
the ABS
contoller is calibrated to 24295 pulses per mile. Input to the
ABS
controller on terminals 9/10 (RR), 12/13 (RF), 14/25 (LF), 22/23
(LR).
This is then transferred to the engine ECM which it leaves as
digital signal
via a CAN link from terminals 79/65 to instrument pack terminals
C1/C7."
1 - 12 of 12 Posts
