1 - 7 of 7 Posts
I plan to add a wideband gauge to my exige in the near future but I don't want to hack up my interior. I want to put it in the engine bay behind the glass between the intercooler and be able to glance at it from my rear view mirror. However, I am not sure if the gauge can survive the engine bay temps? Has anyone done this before?
Thanks
is there an easy way to run the wire through the sill? im putting one in next week have really thought about the mounting part,
on the exige, when i moved it to the cockpit, i went through the passenger side of the car, theres a hole behind the passenger seat that you can get to through the side scoop. elise might be similar.
thanks.
I ran my driverside, all you have to do is take the rear driver wheel off and the wheel liner. Mainly I picked that side since that is where my 3rd O2 bung was at. Didn't even have to remove rear panel. Just flexed it out enough to grab the wire with a coat hanger (mine was probably easier since I removed my 3 point seat belts though). Couple hours work, not too bad.
1 - 7 of 7 Posts
