1 - 4 of 4 Posts
Speed Racer
WHY?
When I first got my Elise it had CF side intakes. I removed those because the brackets were crap and the metal mesh was scratching the paint. I liked the stock look but then nose paranoia set in, and after a track weekend I saw how much crap hit the rear fender flares. I decided to get a CF lip and side skirts more for protection than looks.
WHAT?
Then I looked under the car and saw nut inserts in the front and sides. This car had side skirts and a lip at some point. I could just screw in the parts with zero drilling on the car! That sold me. I got Greg's Race Parts CF front lip, CF side skirts, and a set of brackets for my existing side intakes. I figured if I was going CF I might as well add the intakes. Plus they shield part of the rear fender from rocks and tire bits at the track.
HOW?
Most parts have a template the you mark and then drill into the car. Since I already had nut inserts I made SPIKES! I got some M5 threaded rod and cut into small segments and filed one end down to a point. Then I screwed these spikes into the nut inserts and lined up the parts. Once the part was aligned I taped it with a hammer to make a nick exactly where I needed a screw hole. Then drill through all the nicks and the part was ready to mount. It was simple for the front lip. The side skirts were a little more involved. More on that below...
Top: the original GRP side skirt
Bottom: What I cut is down to
Why?: Nothing wrong with the GRP side skirt, but I wanted mine to mount to the existing nut inserts in the body and GRP mounts to the aluminum frame. Plus I wanted the side skirts very narrow. While I want to protect the bottom edge of the rocker from road debris I also did not want to step over a side skirt while getting out of the car. It is tough enough already. But isn't mounting to the body less sturdy? Yes, but the side skirts now weight about 40% less, plus they stick out less - so less leverage/force can press against the mounts points.
THE SCREW UP
I wanted to notch out the side skirts so I could lift the car at the jack point without removing the side skirt. Unfortunately I took out too much CF so that you could see the notch from the top the car!?! First I calmed down, then I cut a patch of CF from the scrap I had from trimming down the side skirt. Then I used JB Weld Resin and some fiberglass cloth to patch the hole. Pics below. Worked great. After sanding and polishing - you can't tell.
INTAKES
I threw away the metal mesh on the inside of the intakes as it was scarping the car, and replaced it with some generic plastic grill material from Amazon and a rubber strip where it contacted the body. The attached it to the intake with weatherproof silicon glue.
Grill:https://www.amazon.com/gp/product/B01BR0OEOE/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
Rubber:https://www.amazon.com/gp/product/B0721YWC5S/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
RESULTS
I like it. It work's with the black/yellow look of the car, provides some protection, and bolts off in minutes if I ever get sick of it.
Very nice. I as well went on a purchasing spree on Greg's site for some CF bits. The communication with him just makes everything so easy and comfortable to continue giving him my business.
Gabe
To the OP, everything looks great, the one thing I would consider is to put a strip of clear vinyl wrap between the rubber "gasket" for your intakes and the bodywork. I can imagine sand, grit, dust, pollen etc... getting wedged between it, and creating the very problem you sought to eliminate in the first place.
1 - 4 of 4 Posts
