Here is a (unadvertised?) feature in FastWorks. You can use the output from your Wideband O2 sensor and patch it in to the OBD plug. FastWorks will then be able to integrate it into your datalog. I believe it's optimized for AEM EUGO, but Phil has said other systems can be used though it might require adjusting a configuration (not by user though).
First step is order an OBD-2 female pin. I did this by ordering a whole OBD-2 plug from China through Ebay. It was a whole $3 or $4 shipped. I would suggest this method because that way you will get plenty of extra pins in case you ever do something like this again or help a local member. It's also good because it will come with 2 new retaining tabs, which means you can destroy the one that's in the current OBD-2 port.
Run a wire from the Output of the EUGO and crimp one of the OBD female pin on the other end.
Note that end of the pin is shaped a certain way.
Detach the OBD-2 port from below the dash. We are wanting to stick our cable into pin #8.
The top retaining tab needs to be removed. The way I did it was to cut out the little triangles that lock into the housing with some small wire cutters.
Then push the new wire, being sure to align the pin the same way as the others on the top row.
As a reference. You can buy Bosch Wideband O2 sensors for the AEM EUGO from nearly any autoparts store for a very reasonable price. Order Bosch part 17018. This will have the exact same sensor and connector plug.
They are $50-60 and more importantly, can be picked up right then and there.
Once that's all done, all you need to do is enable tactrix.adc8 in the View > Data List menu (towards the bottom).
Sample datalog output. *Note* that the FastWorks software samples at about 20-30 frames per second, so this is only a couple seconds worth of data. The whole datalog was less then 30 seconds long and is almost 2000 lines of data.
*My TargetAFR column is custom added, its a formula of engine.fuel.targetlambda column multiplied by 14.7 =(14.7*D2)
Code:
knock targetlambda iat load rpm timing tps TargetAFR tactrix.adc8
0 0.891156 43.125 143 4509 21.75 36 13.10 12.44
0 0.887755 43.125 144 4523 21.5 38 13.05 10.96
0 0.887755 43.125 148 4542 21.25 40 13.05 12.57
0 0.880952 43.125 154 4582 20.5 40 12.95 11.99
0 0.877551 43.75 158 4588 20.5 40 12.90 9.80
0 0.87415 43.75 161 4594 20.5 40 12.85 11.99
0 0.87415 43.75 163 4621 20.25 41 12.85 9.67
0 0.870748 43.75 165 4656 20 44 12.80 11.80
0 0.867347 43.75 172 4656 19.5 49 12.75 9.67
0 0.857143 43.75 183 4688 19 53 12.60 11.92
0 0.846939 43.75 192 4722 18.25 54 12.45 11.99
0 0.846939 43.75 198 4733 17.75 55 12.45 11.60
0 0.843537 43.75 202 4766 17.5 59 12.40 11.80
0 0.843537 43.75 206 4783 17.5 62 12.40 9.99
0 0.843537 43.75 209 4803 17.5 64 12.40 10.18
0 0.840136 43.75 210 4848 17.5 70 12.35 12.50
0 0.840136 43.75 210 4893 17.25 78 12.35 12.38
0 0.836735 43.75 213 4924 17 88 12.30 10.64
0 0.836735 43.75 217 4937 16.75 100 12.30 13.73
0 0.826531 43.75 220 4980 16.5 100 12.15 13.34
0 0.826531 43.75 223 4998 19.75 100 12.15 13.54
0 0.823129 43.75 224 5033 19.75 100 12.10 13.66
0 0.819728 43.75 226 5057 19.5 100 12.05 11.86
0 0.812925 43.75 228 5121 19.25 100 11.95 14.31
0 0.816327 43.75 229 5121 19 100 12.00 12.05
0 0.812925 43.75 229 5133 19.25 100 11.95 12.05
0 0.809524 43.75 230 5199 19.25 100 11.90 15.60
0 0.806122 43.75 231 5224 19.25 100 11.85 15.60
0 0.806122 43.75 232 5250 19.5 100 11.85 15.66
0 0.79932 44.375 233 5265 19.75 100 11.75 15.73
0 0.79932 44.375 234 5317 20 100 11.75 12.44
0 0.795918 44.375 234 5364 20 100 11.70 14.63
0 0.795918 44.375 234 5382 20 100 11.70 12.83
0 0.792517 44.375 235 5382 20.25 100 11.65 13.73
0 0.789116 44.375 236 5436 20.5 100 11.60 11.34
0 0.785714 44.375 237 5482 20.5 100 11.55 11.73
0 0.782313 44.375 238 5508 20.5 100 11.50 13.54
0 0.778912 44.375 238 5535 21 100 11.45 13.34
0 0.77551 44.375 239 5559 21.25 100 11.40 15.60
0 0.772109 44.375 240 5607 21.25 100 11.35 13.41
0 0.772109 44.375 241 5634 21.25 100 11.35 13.28
0 0.77551 44.375 241 5666 21.5 100 11.40 13.02
0 0.778912 44.375 242 5677 21.5 100 11.45 13.08
0 0.778912 44.375 242 5714 21.5 100 11.45 13.08
0 0.782313 45 242 5769 21.75 100 11.50 11.54
0 0.782313 45 242 5800 22 100 11.50 12.25
0 0.785714 45 244 5838 22.25 100 11.55 12.57
0 0.789116 45 246 5854 22.5 100 11.60 10.83
0 0.792517 45 247 5900 22.5 100 11.65 10.76
0 0.792517 45 247 5921 22.75 100 11.65 12.70
0 0.795918 45 247 5950 23 100 11.70 10.70
0 0.79932 45 248 5995 23.25 100 11.75 10.57
0 0.802721 45 248 6028 23.25 100 11.80 10.57
0 0.802721 45 248 6050 23.25 100 11.80 12.76
0 0.802721 45 248 6095 23.25 100 11.80 10.31
0 0.802721 45 248 6145 23.25 100 11.80 10.57
0 0.802721 45 248 6180 23.25 100 11.80 12.89
0 0.802721 45 249 6208 22.25 100 11.80 12.89
0 0.802721 45 249 6224 22.25 100 11.80 10.96
0 0.802721 45.625 249 6268 22 100 11.80 12.63
0 0.802721 45.625 249 6289 22 100 11.80 10.44
