1 - 4 of 4 Posts
Hi,
I’m thinking of buying an Elise Cup 250. However, I’m living in an apartment complex with a underground garage and a steep ramp. Is it possible to increase the ground clearance by adjusting the double wishbone suspension coupled with Bilstein high-performance dampers and Eibach coaxial coil springs? Every little increase would help.
Thanks!
My car is slammed to the ground and i don't have issues. The short wheel base helps, so if you go sideways, you should be ok
approach all ramp sideways. the long overhang of the eliges will scrape the slight incline
Yes, all the shock versions are adjustable, some more than others. For the yellow shocks, you can remove the c-clip and move them up about 2 notches, or have BIlstein cut new notches.
1 - 4 of 4 Posts
