1 - 10 of 10 Posts
Folks -
I want to get an OBD II reader, and thought would ask for advice before purchasing. While I am open to a stand-alone device, my preference would be for something that I can use with my iPhone 4S (IOS v7) or my MacBook Pro (OS X v10.9) and perhaps connect via Bluetooth.
I will be using it with my 2005 Elise (stock).
Thanks!
— Mike
A lot of the bluetooth readers are for android only. I think the ios ones use wifi but im not sure
DashCommand is the i-phone alternative. Any ELM327 Bluetooth will do ( at least for android ), I think the i-phone version is the Xtool iOBD2. Its all over ebay right now.
The only BT OBD2 reader compatible with iPhone I've found (and bought) is the GoPoint BT1A !
Other devices compatible with iPhone are using WiFi ...
DashCommand is a great iPhone app to use with an OBD2 reader :)
Wow Such Admin
isn't supported by apple for some reason
The reason is apple, its just there business model.
There are a few out there...
Right now I'm using Automatic and it works pretty well. I cleared one code I had without issue, it calculates MPG, tells you when your fuel is low and predicts the milage you have till empty, tracks your drive on a map, tells you where your car is parked, rates your driving based on hard accelerations, hard brakes, and amount of time over 70 (basically just tells me I'm a crappy driver haha).
The Elm327 with the DashCommand app has great reviews and its a cheap setup. I haven't used it personally, but I've heard a lot of good things about it. (BT version, may not work with iOS? Not 100% sure about that though)
The GoPoint BT1 is made specifically for iOS so it should work without issue. You can use their app, DashCommand, or any other of your choosing.
Is there any downside to getting the usb version of ELM327 OBD2 and just using my notebook/laptop etc ??????
Im just looking for a cheap reader myself and came across this thread
Wow Such Admin
The good thing about the wifi one is I can just take the elm327 plug in with me everywhere and use my phone to scan it. That way I can use it on road trips, or while inspecting a used car. I thought about getting the USB one but the wifi one seems so much more convenient.
1 - 10 of 10 Posts
