1 - 7 of 7 Posts
Hey gang!
I finally bought one. I was in love with these cars in college and flew to Chicago after College to buy one... The interior and drive-ability scared me away. Well, over the next decade, literally every time I shopped cars again, I'd search Elises first and dream of owning one. I decided that if I spent a decade vacillating over them, then I should probably just buy one let myself enjoy its quirks.
I purchased one in Denver couple days ago and drove it to Minnesota. The drive was intense. I suspect it may have aftermarket exhaust, as the noise drove me to stop at a walgreens for earplugs. Also it either has a loose ball bearing or else this thing "tramlines" more sporadically than I thought possible.
Overall I'm extremely excited. However, I've found about a half dozen things wrong with it since buying it, which has put a damper on things. Yesterday I typed up a separate post to hopefully get help figuring some of that out. If you're feeling helpful, give a look? https://www.lotustalk.com/forums/f259/new-owner-excitement-thwarted-issues-467214/
Looking forward to getting to know the community :) I feel like this was a longgg time coming
Lance
Addict
I purchased one in Denver and drove it to Minnesota. The drive was intense. I suspect it may have aftermarket exhaust, as the noise drove me to stop at a walgreens for earplugs. Also it either has a loose ball bearing or else this thing "tramlines" more sporadically than I thought possible.
Curious what Elise in Denver you purchased? Maybe some pics?
Good for you.
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
3. The early cars came with misaimed and dim headlights. If you drive at night, convert to HIDs. While better than stock halogen bulbs are available, HIDs throw more light. Stay around 5000k.
5. The best transmission lube I’ve found is Redline MT-90 plus a little Power Punch Extreme Gear Oil Additive. (Note that it takes two changes to get rid of the previous lube.)
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
For street cars, consider removing one or both oil coolers. Some cover them.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Haha thanks guys! I've been too busy to really take pics, but I'll give you what I got!
I bought it from AutoNation Chrysler Jeep in Littleton. Carfax says I'm owner #4. 24k miles. I think it'd been in Colorado for ~ 7 years according to carfax?
ALSO: If you'd like to test your elise knowledge or be a good samaritan, I haven't had any responses yet to my troubleshooting thread. I'm still a bit panicked about my red flashing light scenario.
Thanks!
1 - 7 of 7 Posts
