in Florida, I'd think Tom and Randy could probably help you out. That said, mine stays on as well, and frankly, I don't care. Not a fan of an airbag going off in my face anyway.
Thanks David. You always give very good information please keep up the good work. I am in the Orlando, Fl area. I will contact Jim in the Orlando, FL area, he appear to be very informed on the lotus S4. Thanks again.Like it or not, one day that airbag could save your life. Could be a bad fuse or a plug not connected, you should do a visual check of the system first. I don't know about Florida but in many States you will not pass inspection with a warning light on. Sticking a bypass resistor in for the airbag can only turn the lite off if the airbag is the problem (or you just want to remove the airbag). When you sell the car it could be a problem if the SIR system is not operating.
David Teitelbaum
