1 - 7 of 7 Posts
I have a 2005 Elisse and recently the 1st and 3rd speed on my a/c fan does not work. The 2nd speed works fine and the a/c cools fine. Any ideas what I need to do to fix it??:rolleyes:
Scott Graham
I'm betting its the contacts on the switch. Are you fairly comfortable taking the control switch out of the car to test it with a volt meter? It's probably the easiest part of the system to get to in order to trouble shoot, plus it would cause this issue if those contacts in the switch have gone bad. (shaken loose, corroded, etc.)
but are you getting these symptoms also?
http://www.lotustalk.com/forums/f3/ac-works-fan-speed-1-but-not-2-3-a-58676/
if so, It may be something more serious.... (fingers crossed that it's not..)
Resistor pack is dying. I know - I have the same issue which I'm working on now. Better go look for a resistor pack replacement. So far they're on back order for 2 months... Or you can search up "DIY Blower motor" and you'll see what others did that not only fixed the issue, but increase the output of the blower. Good luck!
My AC blows hot air. No different that when the heats on. I was thinking the thermometer is bad or I need a recharge or both? Thoughts?
If it is blowing "hot" air, the same as with the heater on, I would suspect the flap valve that diverts the air between the heater matrix and the evaporator coil.
Michael
1 - 7 of 7 Posts
