1 - 10 of 10 Posts
In the process of installing my Katana supercharger and was also thinking of installing an air/fuel guage and a boost guage. I wondered if anyone had any write-ups on installing either or had tips/experiences with these installations. All help welcomed, thanks.
With the Air /Fuel you will beed to put another o2 sensor into your exhaust. With the boost guage, you can either "T" off between the bypass valve and intake or install a fitting directly into the intake plenum.. I did the "T" fitting trick, but will likely change it to a dedicated hose fitting in the near future.
Thanks for the help, I appreciate it.
measuring a varying pressure is easier if you install a small orifice to smooth the reading.
this is the trick we use on the vacuum gages when tuning the carbs on a bike.
good luck, i envy you the blower.
sam
1 - 10 of 10 Posts
