1 - 12 of 12 Posts
Administrator
Are these printed or oem clips?
2005 Lotus Elise
I had to get...aggressive with mine to get them back in, which actually involved hitting the corners to get them to seat.. Dont be afraid to ruff it up.
I don't remember having a problem, but if you are swinging it down like it is hinged from above, it is possible the clips are not entering the holes. Shuffle the cover up and down when it is almost in position and see if that is it. You may have to ensure that all 4 are actually in their holes and then give it a bang to get it in
Administrator
Try a shot of Blaster Dry Teflon lube. Won't be messy or attract dirt with a film.
Reactions: Luke D
OP
If none of them clip in them unscrew each of them a full turn. Try to close the panel again with pressure.
Ive removed the panel many times now and usually keep a small stash of the clips handy for a small trial and error. Usually 1 turn out works great.
Reactions: Luke D
2006 Lotus Exige Solar Yellow
Discussion Starter · #12 ·
OP
OP
It worked! Thank you.
1 - 12 of 12 Posts
