1 - 20 of 30 Posts
My battery went low over the winter & it's set the airbag light, dealer can't see me for 5 weeks...:facepalm
btw confirmed that airbag light on means that the airbags are disabled.
The AutoEnginuity tool I have does not support the body modules, has anyone tried the a Opcom tool? This assumes the SRS module is a GM unit as it is in the Eliges.
Hmmm... My airbag light came on when my battery was low as well. I just assumed it was just the idiot light, and that the airbag was still working. That means I've been driving for months with no airbags. Guess I'll have to get off my duff and get that fixed.
only OBDII codes can be scanned all the rest are Lotus Techcentre only, was thinking of buying one but you have to update it every week to keep the license valid and the upfront cost is not cheap. the low voltage code for the SRS system sucks you would think once the issue has been corrected it would reset but no you have to go to dealer just to clear it, never heard of such a (BS) thing.
That thread is about an Elise, what makes you think that the Opcom works on the Evora?
p.s. I have ordered one anyway - they're only $20 on eBay, but would be nice to know if it will work.
Please let me know as mine popped on after a dealer dash part replacement under warranty, and I haven't had time to make it to Orlando...and considering it will cost me $20 in gas....
Oops. Sorry, I didn't realize it was an Evora forum. I have no idea if it will work, but it is cheap and easy to try.
I've had a piece of electrical tape over the air bag light on the track Elise for years after pulling the airbags. Just lazy I guess.
airbag ecu is totally different from engine ecu.
if airbag ECU is GM like in elise and i think it is as lotus recycle like in elise many parts from other car it should work with no problem. Let us know. In elise u have to select Vauxhall astra from 2004 to attach the airbag ecu.
My battery died this winter and was pulled from car for a week. I just replaced it yesterday and no airbag light. Why do you suppose yours would be on?
Is this exclusive to the Evora?
Any news on this?
Discussion Starter #14
Any news on this?
The tool is coming from China (slow boat from...:facepalm) & should be here next week. As soon as it arrives & I have chance to test it I will update here with the results, hopefully next weekend...
I have it, and I think it sort of works, but I haven't gotten mine to clear. It shows my circuit at 1 ohm, where I think it should be about 2. It will clear the code for a split second, but it immediately returns. I think mine might actually be a connector not fully seated, rather than the OP-COM not working, but I haven't taken the time to investigate further.
It's probably obvious to most, but these cheap units are Chinese clones and not the real deal.
Discussion Starter #17
Looks to be KO...
I had a quick go with the Op-Com yesterday & it would not communicate with the Airbag module... I will have another go before abandoning the effort though... Will update either way...:confused:
I didn't realize the post was for an Evora, but for reference, I managed to get my Elise cleared with by properly attaching the airbag connector. It has some weird locking clip that I apparently only had half way engaged. I was on autopilot at the time I hit the "clear codes" button, but I think the code my have actually cleared itself without me having to use the tool.
1 - 20 of 30 Posts
