1 - 15 of 15 Posts
hi there . after 3 years of ownership of my 2011 na ,my airbag light is now reset , just want to put here all info i found from other member
THANKS ALL
i used maxichek pro
Step 1: plug in
Step 2: Select abs/srs
Step 3: Select Asian
Step 4: Select Daewood
Step 5: Select 2011
Step 6: Select (EP) Epica/Tosca
Step 7: Select Body
Step 8: Select SDM (Sensing and Diagnostic Module)
Step 9: Erase Codes
Step 10: Yes
And your airbag light will disappear! I tried to read codes before erasing them and nothing showed up.
:clap:
Just wanted to offer help here if anyone in NVA(DC,VA,MD) needs airbag reset let me know i got Lunch pro that will reset anything.
thanks
ravi
I wish it could be done with Torque Pro. Doesn't come up showing a/bag error and clear codes doesn't clear that one. Interesting that it uses a completely different car profile. Was that trial and error?
I had issue with mine 2 it would come back after hitting some bumps in DC. I would pull the glove box out and make sure big connector is tight and put some dielectric grease on it and zip tie it I put 2 on mine as tight i could get them. good luck
Ravi
Anyone have a reader that will clear my airbag light? Just got back from deployment and needed to jump my car (even know it was on a tender). Any help would be appreciated!
THANKS ALL
i used maxichek pro
Step 1: plug in
Step 5: Select 2011
Step 7: Select Body
Step 9: Erase Codes
Step 10: Yes
:clap:
Just wanted to reaffirm this procedure worked! Picked up the Autel MaxiCheck Pro and worked like a charm. Anyone in San Diego that needs to use it is welcome.
Has anyone had any luck with clearing an ABS light?
Needing to clear the airbag light on my 2017 400, too . . . will this work? I have read conflicting things on both forums.
I just completed this on my 2014 Evora S today, I used the Foxwell NT 360 Elite and worked fine, took me longer to find the OBD port than to clear the code, definitely works!! I bought the Foxwell on eBay for a tad over $100
Good thread! Since @bigbird06815 confirmed that an Autel will work, I can offer my services. If you need an airbag light reset in northwest Oregon, let me know. I get to Portland, Eugene, and Seattle fairly regularly too.
I’m in San Diego and sure could use a reset of the airbag light.
PM me for contact info...don’t mind hooking it up whatsoever. Let me know!
1 - 15 of 15 Posts
