1 - 11 of 11 Posts
Can anyone post some links to past threads about doing an air box delete for the Elise? Having some trouble finding them after doing a lot of searches. Looking forward to an even louder Elise and a little extra air?
I say to ck with BOE, not me.
I'm a fan of the smooth tube intake, K&N filter and snorkel delete. This set up basically maximizes the intake's performance without having to deal with MAF scaling or have any concern with heat shielding /water ingestion.
I might enlarge the airbox inlet to get closer to the cup car airbox inlet to get more sound and throttle response out of the system.
The throttle response makes sense.
I cant imagine much change the sensors cant handle.
As far as colder more dense air, we are talking of dirty, disrupted air. Not clean surface air as from low at the front.
Question... I'm prepping my car for the Torque250, sorting through the mods done before I acquired the car.
The filter/intake was replaced with the red HKS clown nose thing. I'm planning to replace it with the BOE 3" CAI.
Where the ITG Cold Air Box tube goes down to the vent scoop, is there a piece of trim that the tube feeds into? Like that holds in in place to collect and "ram air". Or does the tube just get zip-tied in place down near the side vent?
Listen,
BOE are not amateurs. Moreover, their intake is likely to make the biggest difference if it needs a tune. Logic.
You should know that K&Ns are not very good and are often over oiled, which messes things downstream up.
Also, there is little hp gain, if any, with almost all intakes. The 2ZZ is an efficient engine, so gains don't drop from the sky.
Last, pls read the last entry here:
Stock: “Excuse me”
Stebel: “HONK! LOOK OUT!”
5. Transmission:
And, use:
6. As per some engine builders on these sites, wait AT LEAST 20 minutes after coolant has reached full operating temp before engaging cam switchover.
http://www.lotustalk.com/forums/f311/cooling-ticking-timebomb-how-your-cooling-u-tube-47232/
http://www.lotustalk.com/forums/f320/remote-key-fob-immobilizer-misc-alarm-programming-70940/
14. Visit the Uber Thread
http://www.lotustalk.com/forums/f3/elise-exige-uberpost-read-everything-you-need-know-here-25131/
15. Most parts on the car are made by Toyota and others, so buying things like a/c compressors, engine parts, etc. is wildly expensive when purchased thru Lotus.
16. The soft high-grip tires on most of our cars lose much of that grip when temperatures drop below 50 F. I know of too many ppl who spun their cars when not remembering this. I use hi-performance all-seasons.
Plus, “How to bleed brakes”:
http://www.lotustalk.com/forums/f101/how-bleed-brakes-241138/
How to Search:
Transmission Fluid change what bolt site:lotustalk.com no space betw site:lotustalk.com
Same response as #4, above.
The BOE intake is good stuff. I have one on all 3 of my cars.
It does need to be cleaned periodically. If you get one order some cleaner and oil.
The aero duct on the end just sits down in the scoop area. Not attached to anything.
Yea, I hate to take his time... especially due to this line from his Torque250 description:
"We cannot assist in sorting or compiling parts to create "used kits""
1 - 11 of 11 Posts
