ok so i have searched and cant find anything on the subject. 2 days ago the wife was driving her 2005 elise. went into the store come back 20 min later and could not unlock the car. the tell tale light on the dash is not blinking or lit. called roadside to come get into car. the battery checked good 12.6 volts once in the car the door locks will open with the switch on the shifter console but still no resopnse from fob. as soon as you turn the ignition on the tell tale light starts blinking on the dash and the yellow backlight for gauges comes on and the alarm goes off. turn key off and alarm stops the light on dash goes out and no response from fob inputs. i have checked all the fuses in the car and they are good. used a multimeter pulled each fuse checked and put back. i am 5 and a half hours away from nearest dealer. anybody got a clue as to where i should start looking for the problem before i try to disable and bypass the alarm and imobilizer? thank you
